By Renato Lemus
#59346
When rendering an animation, I set the render time very high for each frame, and I specified a SL to stop the render at that resolution for all frames, but maxwell ocasionally renders a frame with a different brightness or exposure, and that makes the animation to flicker.
p.s. I don't like this "moving" noise. I like it more whe it was a constant noise pattern
By sidenimjay
#59349
i have to disagree about the constant noise . it makes it look like shmootz on the lens
the moving noise feels more like film grain . . . .
Renato, can you show us some frames with render logs?
Thank you,
Tom
By Renato Lemus
#59368
Thanks for the help.
I don't have the log, because I let the pc render when I was out, but the strange thing is that if I render the dark frame again, it renders correctly.
This problem happens randomly.
It was discovered in earlier alpha versions and it seems it's back in the current beta.
check this:
http://www.maxwellrender.com/forum/view ... &start=120
Hi Fernando, Thanks for posting this - much appre[…]
MAXWELL STUDIO CRASH - MEMORY LEAK
Hello everybody, I still looking for the reason M[…]
