#47211
Hi all!
I'm getting bad geometry using realflow. Realflow gives me holes in the
fluid mesh. Tried to use 3dsmax CAP HOLES function, but it didn't work
100%.
Thanks for reading
[[[[[[Scene Setup TAB]]]]]]
Geometry:
Num Meshes: 7
Num Triangles: 269588
Num Vertexes: 135187
Num Normals: 131651
Materials:
Num Emitters: 1
Num Diffuse: 4
Num Metals: 1
Num Plastics: 0
Num Dielectrics: 1
Bitmaps:
Num Bitmaps: 0
[[[[[[== Render settings == ]]]]]]
resolution: 1024 x 614
maximum desired time: 1h 40m 0s
threads: 2
target sampling level: 25.00
>> Starting Render
>> Start Voxelization...
>> End Voxelization...
[0h 0m 27s] of [1h 40m 0s] , current sampling level : 0.00
[0h 1m 10s] of [1h 40m 0s] , current sampling level : 0.00
[0h 2m 12s] of [1h 40m 0s] , current sampling level : 0.85
[0h 3m 36s] of [1h 40m 0s] , current sampling level : 2.72
[0h 6m 7s] of [1h 40m 0s] , current sampling level : 4.51
[0h 10m 54s] of [1h 40m 0s] , current sampling level : 6.26
[0h 20m 5s] of [1h 40m 0s] , current sampling level : 7.99
[0h 30m 5s] of [1h 40m 0s] , current sampling level : 9.07
[0h 40m 3s] of [1h 40m 0s] , current sampling level : 9.81
[0h 50m 3s] of [1h 40m 0s] , current sampling level : 10.38
[1h 0m 3s] of [1h 40m 0s] , current sampling level : 10.85
[1h 10m 3s] of [1h 40m 0s] , current sampling level : 11.24
[1h 20m 8s] of [1h 40m 0s] , current sampling level : 11.57
[1h 30m 4s] of [1h 40m 0s] , current sampling level : 11.87
[1h 40m 22s] of [1h 40m 0s] , current sampling level : 12.13
Render finished successfully :)
Close this window or the frame buffer to End Session...
By ctl3d32
#47213
Fluid density is set to 10.0 and Metaballs (Fluid Mesh) to 0.01. I thought it would give me a very high polycount (and it did). Let's do it again!!!!
Thanks for reading
Alright.. well i'm not a Realflow user so i have no idea what does values mean. But 270,000 polygons for the entire scene including the fluid which take up the most isn't really that much. You could have atleast the double that. Also check your total particlecount, that should work in combination with your meshdensity to calculate the final fluid mesh detail look (i guess).
Is this a static or dynamic fluid mesh ? (animated)
By ctl3d32
#47216
Hi!
It's a ten seconds animation. I choose 1 frame to render. I was looking
at my fluid configuration and i think i found the problem. I was giving the
fluid a fractal noise ( to avoid make it look too smooth ) of 0.8 in amplitude.
I have reduced it to 0.5 and doubled the polycount. Decreased frequecy of
the noise from 4.0 to 1.0. That seemed to solve the problem, but increased
simulation time. Let's see.
By ctl3d32
#47218
Hi!
I will let it render overnight just to see the result!
Thanks for reading!!!
By Becco_UK
#47248
Nice render. I sometimes get a few single polygon holes with meshes from RealFlow3 which are more noticable for static images.
Adjusting parameters in the filters and optimize boxes of RealFlows' mesh section may help.
By ctl3d32
#47339
Hello All!
This is a little update.
MAXWELL 1_2_2a_beta ( Engine core: rs1c )
[ Physically and Unbiased Based Rendering ]
## Scene Information ##
7 meshes ( 116176 triangles )
## Render Information ##
*settings:
*render time: 5 hours 0 minutes 0 seconds
sampling level reached: 16
MaxwellBench 1.0: 24.160499
By ctl3d32
#47340
Hi Becco!
It was just the filter setting that was giving me holes in the mesh. I was
giving some it relaxation...
Thanks for reading!!!!
By ctl3d32
#47346
Hi all!
Here is a Wire of the camera view!!
See Ya!
By Becco_UK
#47353
ctl3d32: Looking at the wireframe image you could get a big polygon count reduction by using the optimise function (using curvature setting) in RealFlow. Edge detail is preserved by retaining high poly's on the areas needed and the flatter/gentle curved areas are reduced quite good.
You probably already knew this already but may be useful for other people new to RealFlow.
By Becco_UK
#47474
Personally, if you revisit this, aim for at least 150,000 particles. Particle count has a direct relationship to final quality of the RealFlow mesh. No matter how much you adjust other settings nothing compensates for having too few particles.
