By Left Side
#43622
A few views of my updated model. Testing SSS and cant seem to get to grips with it!!.
Lights Out
Lights On
Updated again with a bit more detail in the keys
I made a mistake on the bottom set of keys they were sticking out of the main body.
One more, level 13 in 49 mins
C&C Welcome
Left Side
By philipbruton
#43627
looking good, are there emitter objects below the numbers and the numbers have a sss material applied ?
By Left Side
#43636
Yes, but I did loads of tests last night to try and be sure that the SSS was transmitting the light from the emitter. The white keys in the top two images are areas without the sss material and a key window in place. It got a bit late and I settled for something that looked OK but might not actually be doing what it should do!
Left Side
By philipbruton
#43641
As said before in a previous post by oscar i think, when rendering with emitters below objects to reduce noise try and only have emitters for light that is visible, maybe you could create a "1" underneath the sss 1 to emit light through that etc.., thus reducing noise throughout your image and increasing render time n quality.
By Left Side
#43809
Philip,
Thanks for your advise. Time for some more experiments!!
Left Side
