Everything related to Studio
#401771
When opening a file, or after some interactions, the texture decal mode viewport display displays the MXM's selected texture wrong, but FIREs/renders correct. When dragging the material onto the object again, the display is correct, but all projector adjustments one did before are lost and have to be remembered and re-entered anew.
Also, the texture display is very low-res compared to that of modern render softwares.
#401786
Hello Andreas,
It's strange. What happens if you reselect the texture by using this button?
Regarding the texture resolution, you can set it globally from the Preferences > Viewport Rendering > Performance group > Texture Resolution:
I hope this helps.
Best regards,
Fernando
I would guess that the displacement part of the co[…]
20 years?!?!?!
Would have been 20 years. It's dead since long....[…]
Is there any update on whether there will be an up[…]
