By Robert Luger
#401549
Hello Maxwell-community,
I'm using the scatter-extension a lot in combination with plants (flowerbeds, forests, etc..) and it used to work perfectly in Maxwell 4. However, in Maxwell 5 it's currently not working at all.
I'm using Rhino 7 (SR24) and the Maxwell Version 5.2.6.3.
I tested it using a simple box block instance but it produces no results (see below) Also: Apparently I can't set MXS-References in the scatter extension. Do I have to put all MXS- References in a Rhino-block now in order to load them into the scatter-extension?
Am I missing something? Thanks in advance!
