- Sun Mar 20, 2022 3:19 am
#401323
Short tutorial in the form of a 35 page *.pdf. If you work with high dynamic range images in image-based lighting, this is a tool you might want to know about.
Time needed to read the document is about 15 minutes. Objects, materials and Maxwell scene file needed to play around with the first part of the tutorial can be downloaded below.
Slightly revised version. Added a step at the very end. https://www.expandingwave.com/clientdow ... tsMats.zip
https://www.expandingwave.com/clientdow ... enders.zip
- By Mark Bell
