#401256
running the latest Rhino plugin on Rhino 7, I see very ugly redraw issues in the interface. When scrolling there is intense flashing and it is very uncomfortable.
I assume this might have to do with Rhino as much as with how the plugin is coded, but I do not see these issues with any other menu / PlugIn.
would be glad if you can fix this in future versions.
please see the video:
https://mega.nz/file/dBwHRISA#KOypUAgkq ... cYym-KFOxs
By Forum Moderator
#401260
Hello Daniel,
Thank you for reporting the issue. I can see it now on Windows as you pointed it out, but, as I'm using a light interface, it was barely noticeable.
I will let the developer know, although I'm not sure if it will be easy to fix or not. He uses Rhino tools to build the interface, so I guess it's nothing custom. We'll see.
Best regards,
Fernando
By Forum Moderator
#401262
Hello again Daniel,
As I suspected, it seems to happen also in other Rhino-only panels (maybe most of them, very often, don't need scroll, but if you shrink the window, you will see it happening in other panels like the Properties or the Rendering panel in Rhino Render mode, in the Rhino Render Advanced Settings section, for example, which is 100% from Rhino.
Probably, Rhino UI doesn't like long panels...
Best regards,
Fernando
