- Wed Dec 15, 2021 5:31 pm
#401152
Hello!
I wanted to let you know we have just released updates of the plugins for Maya (Maxwell 5 | Maya 5.2.1) and Archicad (Maxwell 5 | Archicad 5.2.2).
Regarding the plugin for MAYA, it comes with several improvements but, first of all, I want to warn you about something important:
WARNING: Please, before installing this version of the plugin, it is important to uninstall the existing one. Do not install over a previous version of the plugin.
Now, let's go with the highlights of this version:
In the case of ARCHICAD, it is just a compatibility update with the latest version of Archicad 25 (Update 2 build 4013) which broke the plugin. It was a complex situation but Graphisoft finally provided a new API and we could generate a fixed version for it to work. Please, note that this version won't work with the previous version of Archicad 25 (Update 1 build 3011). You can find the release notes here but it's just that: https://nextlimitsupport.atlassian.net/ ... on+History
We hope you enjoy them.
Best regards,
Fernando
- We have added support for Maya 2022 but removed Maya 2016 and 2017
- Now the plugin works with Maxwell Render 5.2.1.49
- New Maxwell 5.2 Denoiser implementation and options
- New Substance Painter assistant
- New Substance Designer assistant
- Added support for XGen hair tools (only interactive groom type is supported)
- Several fixes
Best regards,
Fernando
Fernando Tella.
Customer Portal: https://portal.nextlimit.com
Documentation: https://nextlimitsupport.atlassian.net/ ... !spacehome
Other products from the company:
RealFlow: https://realflow.com/
Roombox: https://roombox.me/
- By Maxwell Team
