Everything related to the integration for Cinema 4D.
#400578
In other versions I could see the render region frame as I adjusted it. With 5.2 I can't see the frame so it is guesswork. All the settings look the same as my old installations which worked fine. Also I'm not seeing any textures in the workspace which makes scaling them also guesswork. Also something which worked before. Any ideas ? Don't know if the two issues are linked.
