By greengreen
#400409
I cannot understand how to fix materials on a file started in Rhino 5 + maxwell 4.
I have the material assigned by layer. If I go to the layers tab, and click on the material for that layer, the pop-up window shows a checkbox for "Assign material by plug-in: Maxwell for Rhino".
The material that is assigned does not show up in the materials tab.
If I uncheck the box from the layer material window, I cannot re-check the box. The check box goes away.
Also, the render fails because a texture is missing, but I cannot locate the material to fix it. It does not show up in the material tab.
https://imgur.com/6o4F2oe
