By seghier
#399767
Hello
The script worked fine with old versions 3 and 4 , but don't work with v5, the scenes exported empty with the new material only.
What's wrong here ? i hope it is not a bug :)
Code: Select all
# Read all MXS in a folder, prints some info.
from pymaxwell5 import *
import os
def MXMchangeMaterialFromMXM(mxsFolder,outPath):
	mxslist = getFilesFromPath(mxsFolder,'mxs')
	scene = Cmaxwell(mwcallback_cb)
	for mxs in mxslist:
		#print str(mxs)
		name = os.path.splitext(mxs)[0]
		print name
		scene.readMXS(mxs)
		newMatName, descr, im, ok = CmaxwellMaterial.getMxmInfo(newMatPath)
		newMat = scene.createMaterial(newMatName)
		newMat.read(newMatPath)
		it = CmaxwellObjectIterator()
		obj = it.first(scene)
		while not obj.isNull():
			# update object material
			print('Object: '+obj.getName()[0])
			objMat = obj.getMaterial()[0]
			if not objMat.isNull():
				print('  Material: '+objMat.getName())
				if objMat.getName() == oldMatName:
					obj.setMaterial(newMat)
					print('  UPDATED -> '+newMatName)
			# update triangle group material
			itGroup = CmaxwellObjectTrianglesGroupIterator()
			group = itGroup.first(obj)
			while not group.isNull():
				print(' Group: '+group.getName())
				# get group material from the 1st triangle of the group
				triangles = group.getTriangles()
				groupMat = obj.getTriangleMaterial(triangles[0])[0]
				print('  Material: '+groupMat.getName())
				if groupMat.getName() == oldMatName:
					group.setMaterial(newMat)
				group = itGroup.next()
			obj = it.next()
		outputpath = outPath+'/'+name+'_updated.mxs'
		if not scene.writeMXS(outputpath):
			print('ERROR: cannot save '+outputpath)
			return 0
	return 1
	#return 1;
if __name__ == "__main__":
	oldMatName = 'plane'
	newMatPath = 'C:/maxwell tool v5/materials/leather.mxm'
	mxsFolder = 'C:/maxwell tool v5/animation'
	outPath = 'C:/maxwell tool v5/output'
