By Mike Amos 20200501214323
#399671
OK, when I give a colour/group a property of an hdri, it scales so there are multiple images on the group when I render. Not sure why. Any tips?
By Forum Moderator
#399851
Hello Mike,
I'm not sure what you are doing with the HDRI. Could you, please, describe the situation with more detail? A screenshot would help to understand the issue.
Best,
Fernando
By Mike Amos 20200605091500
#399878
G'day,
I placed a rectangular face outside a window with a flat colour and assigned it a hdri in the emitter range.
By Forum Moderator
#399899
Hi Mike,
That has to do with the default mapping of that object.
If you are trying to map the image 1:1 on the plane without any tiling and fitting exactly to the plane, I'd suggest using the HDRI Light from the toolbar:
In this case, it will fit exactly to the plane (Option A in the image below).
On the other hand, if you want to edit the mapping, you will have to save a copy of the hdri image in a format that SketchUp can read (like jpg or png); this way, you can apply it to the SketchUp material so you can see it in the viewport (Option B in the image below), as SketchUp cannot view HDRI images in the viewport; then right-click on the plane, locate Texture entry > Position
You will get to the texture positioning tool from SketchUp:
Cheers!
Fernando
