#399527
I've been using Maxwell for years, but was never very good at material creation, usually adapting pre-existing materials from the library to suit my needs.
However I've come to an impasse trying to create a roughcast lime render material, which has a kind of oatmeal kind of texture. Reference below:
https://s3-eu-west-1.amazonaws.com/spec ... 0de3e6.jpg
Would prefer it to have displacement. Any help on how to create this would be welcome!
Many thanks
B
#399531
Whoops! I made an error in the material I just attached to the previous post.
There is a 564x564 normal map within the textures directory of that material that looks like your "roughcast." In my hurry, I put this in the bump map slot, as a normal, with 300% value. Instead, for displacement, you need to add a displacement option to your layer (or a second layer), and load that bump map into the displacement setting. Just ignore the diffuse color setting I use, and use your own. Apologies - I am in a hurry to complete another assignment.
#399532
Forester wrote:
Sat Mar 28, 2020 5:49 pm
Thank you Forester! This worked perfectly!
