By Tyrone Marshall
#42526
dacct wrote:1. window size - it's quite annoying to have the window starting in full screen. It would be nice to have a few options available:
1.1 automatically resize to fit image resolution (or full screen for images larger than screen resolution) - this option could be set for when the window opens, or via a button available in the GUI to quickly reset and optimize the window size
1.2 remenber last position/size - this could be an alternative option for opening the window
2. "1:1" button to quickly reset the image to its original resolution (+ possibility "fit" button to fit the image within the viewer)
3. save log menu - it's always useful to save render time information (ie for knowing how long it would take approximatively to re-render some files at some later time). I have also requested a command line option for saving the log.
4. to make it more real-life like - it could be nice to have the sliders snap to real life values for some parameters (ie 100, 200, 400, 800, etc. for Film ISO; 1/8000, 1/4000, 1/1000. 1/500, 1/250, 1/125, 1/60, 1/30, 1/15, 1/8, 1/4, 1/2, 1 or -1, -2 etc. for Shutter Speeds). This option could be set via a check mark, or predefined the values in a pop-up, or by pressing the ALT key when moving the slider, etc. When the option is off, one could enter any values.
Render logs are saved to the "output" folder of your maxwell render program folder.
did you tried luxCore?
