By bobross
#398809
Not sure if this is engine, CPU, GPU or Dual GPU related.
I downloaded the scene https://rayflectar.com/p05-Misc/files/T ... nStress.7z (Light Distribution Test )
from https://rayflectar.com/p05-Misc/misc.html
Using 2x1080 NVidia GPU after it get to SL 22ish the Time Left starts to freak out and keeps resetting each .xx SL update.
EDIT:
Just came across another strange issue...
Rendering in dual GPU with this scene https://rayflectar.com/p05-Misc/files/G ... ion(01).7z (Metalic Object Caustics)
The render starts normal. Around SL 22 output window starts scrolling really fast. The time left went down from about 1 hour left to 34 seconds but keeps resetting. Also the Render complete % bar is jumping back and fourth now e.g 95%, then 97% then 95% again.
