#398499
Dear customers,
We have just released a new version of the plugin for Rhino 6: Maxwell 4 | Rhinoceros 4.2.6.4
You will find the new panel to manage the custom alphas and several buttons related to custom alphas functionality; we have also synchronized Maxwell's sun with Rhino's one when you opt to use it.
As always you can find it at the portal: https://portal.nextlimit.com
In case you want to check the changes in more detail here are the release notes:
Publish date: Wed, 07 Oct 2019
Additions:
  • New Custom Alpha panel and functionality which allows managing the assignment to objects (for the moment, it doesn’t work for materials)
  • New Custom Alpha section in Object’s properties area.
  • New Custom Alpha option in Extra Sampling mask type parameter.
  • New buttons to open Custom Alphas panel from Maxwell’s Object Properties and from Maxwell Render Settings > Output tab > Channels > Custom Alpha
  • New About box in Maxwell menu
Changes:
  • "Use Rhino Sun" has been renamed to "Sync with Rhino Sun" (it reflects the behavior better).
  • "Sync with Rhino Sun" is now at the top of the Maxwell Sun settings.
  • In "Sync with Rhino Sun" mode the Maxwell Sun Type and the Rhino sun states are always in synchrony. Changing Maxwell sun type can change the state of the Rhino Sun / or changing the state of the Rhino Sun can change the Maxwell Sun Type.
We hope you enjoy it.
Kind regards,
Fernando
