- Sat Sep 14, 2019 1:54 am
#398447
Hi there,
after a texture tag has been assigned to a large (4000x4000 cm) object, I couldn't scale or move the texture tag if using a Maxwell Procedural as texture.
Using a C4d material I can scale it, move and rotate the texture tag fine with my limited knowledge of C4d
I suppose that Procedrals must be set in MXED, but there are only frequency, repeat and similar parameters there, making possible only to reduce the size of the texture. Should I look for a particular parameter in order to make the procedural texture look bigger?
Thanks in advance,
Camillo
Thanks in advance,
Camillo
