By piroshki
#398443
Hi Fernando,
I decided to play around with the new plugin today, and am getting my first Rhino crashes in months. If I hit "render" it will sometimes start to render, but sometimes I will get a hard crash for Rhino.
In fact I just had to restart my computer for the first time in a long time as Rhino refused to start and would immediately crash. The only thing I have done is install the new plugin a few hours ago.
Can you think of any reason this might be happening? The model I am trying to render isn't that big... I do notice that CPU and memory usage spike just as I hit render. It looks to me like this is happening before Maxwell gets called, so perhaps when it is preparing the scene file? Anything I should look at?
Thanks
Tom
By piroshki
#398444
Just had this happen again, and this time I had the task manager open. CPU didn't pass 50%, however memory (in use) went from about 6 GB to 15.9 GB (I have 16 gb on my machine). Committed memory climbed to 40 GB (!!!) before crashing. So IMHO there is a memory leak in there somewhere...
By piroshki
#398445
Sorry for the multiple posts... This is what a successful render look like (see first image).
Second and third images show what happens before a crash.
By piroshki
#398446
Having fun on my own thread here :)
It appears that one (or several) surfaces were causing a problem. This does not happen with the R5 plugin. There must be some code in there to prevent this crash from happening.
