By Forum Moderator - Tue Jul 16, 2019 2:13 pm
#398329
Hello!
We have just released a new version of the plugin for Rhino 6: Maxwell 4 | Rhinoceros 4.2.6.2
It finally solves the problem when installing the plugin on Windows 7 and 8.1 and also the licensing problem with users that had non-English characters on the license
As always you can find it at the portal: https://portal.nextlimit.com
Here are the release notes:
Maxwell 4 | Rhinoceros V6 4.2.6.2
Publish date: Tue, 16 Jul 2019
Improvements:
Improvements:
- Moving meshes under FIRE can be faster now.
- Dialog with text message helps to identify Maxwell initialization failures.
- Plugin could not read the license if it contains non-ASCII characters.
- (Win7 and Win8.1 only) Plugin made Rhino crash at program start.
- Views with similar names could confuse the Maxwell exporter.
- Moving object in FIRE mode which had Maxwell Spotlight Emitter material could crash Rhino when using Fire.
Fernando Tella.
Customer Portal: https://portal.nextlimit.com
Documentation: https://nextlimitsupport.atlassian.net/ ... !spacehome
Other products from the company:
RealFlow: https://realflow.com/
Roombox: https://roombox.me/
- By Matteo Villa
