By Forum Moderator - Mon Jun 10, 2019 3:53 pm
#398225
Dear users,
We have just released Maxwell 4 | 3dsmax 4.2.6. You can find it at the portal as always: https://portal.nextlimit.com
We have added support for 3dsmax 2020 and made some fixes and improvements.
We hope you enjoy it. Here are the release notes:
Publish date: Mon, 10 Jun 2019
Additions:
Additions:
- Added support for 3ds Max 2020.
- The bounding box of a referenced mxs is not including the origin of the scene anymore so if you try to center the pivot on the reference, it will actually center on the geometry.
- The plugin was ignoring Max's region render parameters when launching the render to the network. Now it should be taken into account.
- Launching animation renders directly (without using Maxwell sequence rendering) sometimes skipped some frames when doing it from 3dsmax 2017, 2018 or 2019. It is now fixed.
- 3ds Max crashed if you tried to export to mxs without having Maxwell set as render engine.
- The asset tracking tool now is aware of mxm and mxs references so you can use it to repath the references to a different folder easily.
Fernando Tella.
Customer Portal: https://portal.nextlimit.com
Documentation: https://nextlimitsupport.atlassian.net/ ... !spacehome
Other products from the company:
RealFlow: https://realflow.com/
Roombox: https://roombox.me/
- By Mark Bell
- By Mike Amos 20251018183343
