#398034
Hi Juan, does the job start to transfer to the nodes and then it just does nothing? If so, it may be that EACH node need to have their temp folders cleaned out. Navigate to C:/Users/Admin/Local/Temp/mxnetwork and erase all files. You may also use the "Purge Temp Files" from the File menu. I've had this issue a few times also and this seems to clear the problem.
