By Forum Moderator
#397558
Hello,
We have just uploaded Maxwell |3dsmax 4.2.4 to the portal.
It fixes some bugs mostly related to the Assistants.
As always, you can get it from the Customer Portal in "My Downloads" area: https://portal.nextlimit.com
We hope you enjoy them.
Here are the release notes:
Maxwell | 3dsmax 4.2.4
Publish date: Wed, 05 Sep 2018
Fixed:
  • In the case of Assistant Materials, when loading a bitmap the parameters disappeared from the UI.
  • Maxwell bitmap was showing only part of the parameters when loaded into an assistant.
  • Override Map functionality was not working at all in the case of assistants.
  • Occasional crashes when manipulating the Maxwell bitmaps parameters in the assistants.
Known issues:
  • Still, there are some quirkinesses in the interface when using the assistants that would require a bigger restructuring of Maxwell bitmap.
