Everything related to Studio.
By Giusy La Licata
#396342
Hi guys.
I have a question regarding the deformation of assisgned materials to the geometric form in the attached pictures.
in one picture i want the stone tiles to be smaler as rendered, because they are to stretched out than they should be.
how can I can I adapt the material to the form?
In the other picture I added a displacment to the stone material, but it completly disformed it.
how do i adapt that?
I hope I expressed my problem clearly
thank you for your help
Have a look at working with UV sets in Studio:
http://support.nextlimit.com/display/ma ... +in+Studio
About displacement, you have to change the subdivision amount in the displacement component of the material depending on how many polygons your geometry already has. More info here:
http://support.nextlimit.com/display/ma ... +component
