By Q2
#395939
No, I have a series of files where I need to change the emitter value also from 0-100 Percent...Exept this time I use an MXI as my light source and not a regular Maxwell emitter with wattage.
Now that I think of it, maybe it would work with your script anyway....
Checking....
#395942
This should do the trick:
Code: Select all
#============== CHANGE THESE VARIABLES AS REQUIRED ==============
mxs_dir = 'C:/Users/<user name>/Desktop/mxsfiles'
mat_name = 'Emitter'
intensity_min = 0
intensity_max = 100
#=================  DON'T CHANGE ANYTHING ELSE  =================
import os
import sys
from pymaxwell import *
mxs_dir = os.path.normpath(mxs_dir)
if not os.path.isdir(mxs_dir):
   print('ERROR: input dir not found: %s' % mxs_dir)
   sys.exit(1)
mxs_files = getFilesFromPath(mxs_dir, '.mxs')
if not len(mxs_files):
   print('ERROR: no MXS files found: %s' % mxs_dir)
   sys.exit(1)
mxs_files.sort()
incr = (intensity_max - intensity_min) / float(len(mxs_files))
intensity = intensity_min
def read_emitter(mxs_path):
   mw = Cmaxwell(mwcallback)
   if not mw.readMXS(mxs_path):
      print('ERROR: Failed to read %s.' % mxs_path)
      mw.freeScene()
      return None,None,None
   material = mw.getMaterial(mat_name)
   if material.isNull():
      print('ERROR: Failed to find "emitter" material in %s.' % mxs_path)
      mw.freeScene()
   layer = material.getLayer(0)
   if layer.isNull():
      print('ERROR: Failed to find layer 0 for "emitter" material in %s.' % mxs_path)
      mw.freeScene()
   emitter = layer.getEmitter()
   if emitter.isNull():
      print('ERROR: Failed to find emitter for layer 0 in %s.' % mxs_path)
      mw.freeScene()
   mxi,ok = emitter.getMXI()
   if not ok or emitter.isNull():
      print('ERROR: Failed to get mxi for layer 0 in %s.' % mxs_path)
      mw.freeScene()
   return mw,emitter,mxi
for mxs_file in mxs_files:
   mxs_path = os.path.join(mxs_dir, mxs_file)
   mw,emitter,mxi = read_emitter(mxs_path)
   if not mw:
      continue
   mxi.value = intensity
   emitter.setMXI(mxi)
   if not mw.writeMXS(mxs_path):
      print('ERROR: failed to write %s' % mxs_path)
   else:
      print('OK: adjusted mxi intensity to %s in %s.' % (intensity, mxs_path))
   mw.freeScene()
   intensity = intensity + incr
Caustic render channels
Try selecting refractions in render channel and in[…]
First Maxwell render for some time!
Hi, A just for fun project to model and render th[…]
Hi everyone, has anybody found a way to use and e[…]
Modeling from spline
Thanks - I came across the same thing myself recen[…]
