By CDRDA
#394606
...With copies of mxs references. The original reference is hidden as should be when set to enable, but each copy (created using the move tool) in Sketchup is visible in FIRE and the production render. I've double checked all references have the hide from camera flag set to enabled and also tried making the copy before and after setting the hide to camera option.
Using latest 4.1 versions of all Maxwell programs/plugins, but this was an issue a while back as well. Is this a limitation in the way Sketchup handles references?
#394617
My initial tests show that this works the same in the 3.2.5 and current 4.x plugins. I am not sure, before looking more deeply into it, whether this is a limitation (whether of Maxwell or the plugin), but I'll look further and let you know.
