Everything related to the integration for 3dsmax.
By devista
#394561
What am i doing wrong??
When the render finish always the message and maxwell don´t save the mxi.
Sorry but I do not know how to attach a screen captura :(
Saludos
Luis
By Forum Moderator
#394609
Hi Luis,
When does it happen? When using Denoiser, Network Render, single render in Maxwell,...?
Which version are you using? I cannot reproduce it here with the latest version.
For attachments, you should have an Attachments tab under the text box, next to Options.
Cheers!
Fernando
By devista
#394640
Cuda toolkit instaled (1,20 GB :shock: :shock: )
Render with denoiser from 3dmax.
Same error.
With cpu:
Only save the render image but not the denoised. Not save the mxi. (normal, don´t can merge the mxis)
With gpu:
Save the render image and the denoised. Not save the mxi.
The temporals mxi are saved on the users/temp... not in the indicated path
Saludos
Luis
#394730
Hi Luis,
Does this always happen to you with every render or it's just a particular case?
I cannot reproduce the problem here. If you could give me a step by step guide to reproduce it with a simple scene it would be of great help.
Gracias!
Fernando
#394910
Gracias Fer,
at the end I had desinstalled the v4. But I have a new problem. Now the v3 don´t recognize the license. I have a case open in the Next Limit Portal. I´m waiting for the response. :( . All was more easy with the v2 :lol: :lol: I am responsible for testing v4 :cry: :cry:
Saludos
Luis
