By F. Tella
#394137
Hello!
We are releasing a quick Early Build to solve a couple of important issues: Early Build 4.0.1.1
Warning: MXI backward compatibility broken due file format change. Older maxwell render are not able to open 4.0.1.1 MXI files.
You can get it from here: http://www.maxwellrender.com/betas/
And these are the releases notes:
4.0.1.1
Publish date: Mon, 20 Feb 2017
MAXWELL GPU
- Fixed bad MXI file saved when engine is GPU and normals channel is enabled. MXI backward compatibility broken due file format change. Older maxwell render are not able to open 4.0.1.1 MXI files.
MAXWELL RENDER
- CPU render engine performance improved about 10%. Now Maxwell 4 and Maxwell 3 has the same performance.
