By zparrish
#393757
I'm running Maxwell 4.0.0.12 and its network management tools. When rendering a cooperative render, if I try and preview it through the monitor application, a Qt error pops up on all of the render nodes assigned to that job. It reads:
Code: Select all
QString::arg: Argument missing: Preview sent, 100
The end result in the monitor application is simply a console message of:
[04/January/2017 12:33:23] Requesting display...
There's no additional console message in the monitor and the merge request never actually completes with output to the monitor. Here's the list of console message related to the merge that showed up on the Manager application:
[04/January/2017 12:33:24] Display request from monitor: <IP Address>
[04/January/2017 12:33:24] Requesting display of job 1
[04/January/2017 12:33:24] NEW Display recepcion thread: Node:
[04/January/2017 12:33:24] Node: MUN-RN17: render_info: Sending preview...1 percent
[04/January/2017 12:33:24] Node: MUN-RN16: render_info: Sending preview...1 percent
[04/January/2017 12:33:24] Node: MUN-RN18: render_info: Sending preview...1 percent
[04/January/2017 12:33:24] Node: MUN-RN11: render_info: Sending preview...1 percent
[04/January/2017 12:33:24] Node: MUN-RN11: render_info: Sending preview...74 percent
[04/January/2017 12:33:24] Node: MUN-RN15: render_info: Sending preview...1 percent
[04/January/2017 12:33:24] Node: MUN-RN15: render_info: Sending preview...74 percent
[04/January/2017 12:33:24] Node: MUN-RN14: render_info: Sending preview...1 percent
[04/January/2017 12:33:24] Node: MUN-RN14: render_info: Sending preview...74 percent
[04/January/2017 12:33:24] Node: MUN-RN13: render_info: Sending preview...1 percent
[04/January/2017 12:33:24] Node: MUN-RN13: render_info: Sending preview...74 percent
[04/January/2017 12:33:24] Node: MUN-RN12: render_info: Sending preview...1 percent
[04/January/2017 12:33:24] Node: MUN-RN12: render_info: Sending preview...74 percent
[04/January/2017 12:33:24] Node: MUN-RN00: render_info: Sending preview...1 percent
[04/January/2017 12:33:24] Node: MUN-RN00: render_info: Sending preview...74 percent
[04/January/2017 12:33:24] Node: MUN-RN00: render_info: Preview sent
[04/January/2017 12:33:24] Node: MUN-RN17: render_info: Sending preview...74 percent
[04/January/2017 12:33:24] Node: MUN-RN17: render_info: Preview sent
[04/January/2017 12:33:24] Node: MUN-RN13: render_info: Preview sent
[04/January/2017 12:33:24] Node: MUN-RN16: render_info: Sending preview...73 percent
[04/January/2017 12:33:24] Node: MUN-RN16: render_info: Preview sent
[04/January/2017 12:33:24] Node: MUN-RN14: render_info: Preview sent
[04/January/2017 12:33:24] Node: MUN-RN12: render_info: Preview sent
[04/January/2017 12:33:24] Node: MUN-RN18: render_info: Sending preview...74 percent
[04/January/2017 12:33:24] Node: MUN-RN18: render_info: Preview sent
[04/January/2017 12:33:24] Node: MUN-RN11: render_info: Preview sent
[04/January/2017 12:33:24] Node: MUN-RN15: render_info: Preview sent
[04/January/2017 12:33:25] Display thread finished. File received from: MUN-RN00: OK
[04/January/2017 12:33:27] Display thread finished. File received from: MUN-RN13: OK
[04/January/2017 12:33:27] Display thread finished. File received from: MUN-RN12: OK
[04/January/2017 12:33:28] Display thread finished. File received from: MUN-RN15: OK
[04/January/2017 12:33:29] Display thread finished. File received from: MUN-RN11: OK
[04/January/2017 12:33:29] Display thread finished. File received from: MUN-RN14: OK
[04/January/2017 12:33:29] Display thread finished. File received from: MUN-RN17: OK
[04/January/2017 12:33:29] Display thread finished. File received from: MUN-RN18: OK
[04/January/2017 12:33:31] Display thread finished. File received from: MUN-RN16: OK
[04/January/2017 12:33:56] Merging display process finished successfully!
The render is still in progress, so I'm not sure what will show up in the console(s) when it reaches it's targeted Sampling Level. I'll add that to this post if it ends up relating to the preview request. I'm assuming it will simply do the cooperative merge to finish up the Job as usual with no mention of the incomplete preview request. Thanks!
