By PeterP
#391882
Traditionally command line flags that take a Boolean type value can accept True/False and 1 or 0 (integer) values.
The Maxwell parameters listed here - http://support.nextlimit.com/display/mx ... Parameters - some take on/off, some yes/no - some both. Can the True/False 1/0 values be added? Would make scripting much easier.
This is just one of many things that would help Maxwell operate better in a production environment.
Pete
