By Q2
#391698
Since I setup all my stuff in Maxwell Studio and therefor use two camera views in my Studio layout, it would be great if I had a lockable "Render View" that does not change when starting FIRE.
Right now, if I change an emitter, or rearrange it in the perspective view, the Renderview switches to the same Perspective settings and after FIRE has started I manually have to change the renderview back to the original state.
Maybe I am missing something here, but so far I have not found a solution to FIX the Renderview in any way when using two camera views in Studio!
Cheers Q!
