By deis
#390988
I use maya with Z-up, and unfortunately, the 'Grow Toward World-Y' cannot be used in this case...
Is it possible to set this parameter to Z ?
edit.
I think there is another problem.
When I use a initial angle map, the preview and the render are not similar.
That seems correct on the preview only.
I suppose a switch between axes because of the Z-up
Thanks
-Pascal
