- Tue Apr 26, 2016 7:17 pm
#390848
Hello!
We have uploaded a new build of Maxwell to the Early Builds site. It is version 3.2.1.3.
You can get it here: http://www.maxwellrender.com/betas/plugin/22
It includes several important bug fixes like the elusive one with Color Multilight!
We hope you enjoy it.
These are the release notes for this version 3.2.1.3:
- Studio. Adding objects with children to a custom alpha channel doesn't adds the first children. Plus, "group" objects are added to the channel too, with no effect on the channel result.
- Maxwell Render. Userdefineds and instances not getting projectors when referenced.
- Maxwell Procedurals Extension. Bugfix with randoms in procedurals.
- Network. Always connect to manager text field now admits either IP address or hostname.
- Maxwell Render. Memory leak dealing with PNG files.
- Studio. Error getting diffuse color of fbx material.
- Studio. When IES file is present but emitter lobe is not IES, the IES lobe is not drawn.
- Network. XML messages sent through sockets corrupted due non ascii characters.
- Network. Invalid size sent through sockets that could corrupt xml messages.
- Maxwell Render. Artifacts with color ML.
- Maxwell Render. Check material layer weight/opacity for bitmap and throw error if not enough uv channels.
- Maxwell Render. Bug loading standard projectors applied to Userdefineds.
- Maxwell Render. Caustic flags were not working properly in Draft mode.
- Maxwell Render. Hostid shows up in license info window.
- Network. Now it is possible to select several jobs at once to change its priority in one step.
- Maxwell Render. Regular pretessellated displacement was ignoring negative values (vector displacement was working fine).
- Maxwell Render. Check against out of range multilight command line parameter.
- Pymaxwell Editor. Editor is not able to write the "]" character since 3.2.1.1.
- Onshape. License bugs.
Best wishes,
Fernando
Best wishes,
Fernando
Next Limit Team
Customer Portal: https://portal.nextlimit.com - Documentation: http://support.nextlimit.com/
Other products from the company: RealFlow: https://realflow.com/ - Roombox: https://roombox.me/
