By cscartdept
#389755
The plugin runs fine at first, but freezes on refresh or re-render. If I close the program and run again, I get the black splash screen, the links and a status at the bottom left as 'Updating Output...'.
#389756
Please make sure you are using the most current plugin (version 3.2.3, available here), and if you already are, then please let me know more about your situation (OS & version, SketchUp version, whether it occurs with a simple model, or involves the use of MXS References, volumetrics, and such).
By cscartdept
#389758
JDHill wrote:Please make sure you are using the most current plugin (version 3.2.3, available here), and if you already are, then please let me know more about your situation (OS & version, SketchUp version, whether it occurs with a simple model, or involves the use of MXS References, volumetrics, and such).
Done. So far so good. Curious why these appear to pop up recently (since two weeks ago).
#389759
It's not really possible to say much without knowing more about the situation. What you described sounds like an issue that was fixed in plugin version 3.2.1.
