By F. Tella
#389735
Hello all!
We have just uploaded a new version of Maxwell Render to the Download Area in the Customer Gateway! It is 3.2.1.0 (this will never happen again, he he)
Here are the release notes: http://support.nextlimit.com/display/mx ... ease+Notes
You can get it from here: https://portal.nextlimit.com/
MAXWELL RENDER 3.2.1.0
- Improvements in voxelization performance
- Fixed more details in the Onshape connection
- Default value for parallax distance in Lat-Long Stereo lens changed from 3600 to 360
- pymaxwell editor improved to ident/unident blocks of text. Dropping files fixed
- Studio: fixed some procedural textures were displayed in the GUI when they should not
- Fix bug when opening single "Y" channel EXR files.
- Brick procedural texture: fixed random problems with missing paths. Fixed using procedural textures inside map parameters of brick procedural
It includes this fixes listed above as well as all the ones included in the previous early builds, we encourage everybody to use this one instead of 3.2.0.0.
Fixes included in Early Build 3.2.0.4
- Fixed performance issues during voxelization (update your plugin when available)
- Fixed potential crash with motion blur in objects with children
- Improvements in floating shadows in FIRE
- Pymaxwell editor improved
- Fixed some GUI issues
- Studio: Fixed when exporting MXMs material names were cropped if they contained dots
- HDR Light Studio: Fixed problems loading problems under certain scenarios
- Network: Better detection of IP address or hostname of the manager to connect to.
Fixes included in Early Build 3.2.0.3
- Fixed several bugs with stereo lenses
- Fixed some Mac GUI issues
- Fixed extensions presets were not loading some map parameters correctly.
- Fixed scene_dependencies.ms script was obsolete.
- Fixed bugs with HDR Light Studio connection
- Improvements in the Onshape connection
- OpenVDB updated to v3.0
Fixes included in Early Build 3.2.0.2
MAXWELL
- Fixed some threading issues that could be affecting stability
- Fixed some details in hair material assistant
- Onshape connection: fixed bugs in several areas
STUDIO
- Fixed procedural textures were not working with new stereo lenses
- Fixed some gui issues and default values in lens extensions (StereoFish and Lat-Long Stereo)
- Fixed HDR Light Studio v4 was not loading correctly
NETWORK
- Fixed issues with batch renders when Monitor and Manager where running Windows and nodes were running Linux
- Fixed preview jobs was not working
