- Fri Jul 31, 2015 8:41 pm
#387579
Does anyone know a way to use the Maxwell UI to batch process MXI files so that they export to EXR's with embedded alpha information? If I manually export a single MXI file and answer "Yes" to "Embed channels" while there is a main alpha channel (not just custom alpha channels), it will pre-multiply the alpha channel into the main pass, creating an RGBA channel within the EXR file.
So far, I can only seem to get the batch MXI functionality to only separate the alpha channel into a separate file.
I figured I could probably script this, but I wanted to know if it were possible through the UI.
Thanks!
Thanks!
Regards,
Zack Parrish
Maxwell - 4.2.0.3
Maxwell 4 | 3ds Max - 4.2.4
336 capable Maxwell threads!
Workstation:
Dual E5-2680v3, 64GB, Quadro K5200
48 threads (HT) @ 139.2GHz
Render Farm:
288 threads (HT) @ 835.2GHz
Zack Parrish
Maxwell - 4.2.0.3
Workstation:
Render Farm:
- By Mark Bell
- By Edward Leibnitz
