By mwilchrlx
#384390
Running fedora 12
maxwell 3.0.0.0
signal 11 crash does not occur on windows, with the exact same MXS file.
I have tested maya 2014 and 2015, and the crash is repeatable from all versions.
shutting off the embedded .EXR channel successfully renders the scene. All other embedded channels render fine, the crash is exclusive to a scene with an added custom alpha channel.
Crash log entry:
maxwell
Signalhandler. Code: 11
QObject::setParent: Cannot set parent, new parent is in a different thread
X Error: BadIDChoice (invalid resource ID chosen for this connection) 14
Major opcode: 1 (X_CreateWindow)
Resource id: 0x4a0011f
Extension: 151 (RENDER)
Minor opcode: 4 (RenderCreatePicture)
Resource id: 0x4a00120
Major opcode: 55 (X_CreateGC)
Resource id: 0x4a00121
maxwell: xcb_io.c:242: process_responses: Assertion `(((long) (dpy->last_request_read) - (long) (dpy->request)) <= 0)' failed.
Signalhandler. Code: 6
^CAbort (core dumped)
