By choo-chee
#382879
Hi all, a small question:
Is there a way to select many objects together then change an attribute of maxwell with a single tick?
I mean, let's say I've placed 100 emitters and forgot to tick "hidden from camera".
Now I have to select 1-by-1 and tick it, is there a way to tick'em all together ?
#382886
Select the objects, then go to window -> general editors -> attribute spread sheet. The Maxwell attributes are toward the end of the list, and you can select an entire column and type the value you want to set.
By choo-chee
#383061
thanx again and another question regarding this (I know it's not maxwell but it appears you're the best man to ask about maya):
I made a mistake, did tons of planar projections of a cladding material on many objects, and forgot to set the same Y value to each project so now I have mismatching cladding strips.
Is it possible to gather all planar together and change it just one time ? thanx again !
