#382174
When i open the MXM editor from 3DSmax material editor (slate) and then switch the texture display size of the texture picker to the bigger window (not full size),
the window stays open and drag&drop of textures into the texture list window is not possible anymore. Switching back to the normal image preview doesn't help,
i have to close the editor and re-open it to make it work again.
Opening MEXD directly without max doesn't show this problem. It closes the bigger preview window every time i close the texture picker and texture list is working as it should.
- Maxwell v3.0.1.3, plugin v3.0.33 (plugin shows engine version 3.0.1.2), Max2014, Win7 x64 SP1
