By dariolanza
#381530
Hello seghier,
We did, we included gravity on the Grass generator for these kind of purposes.
Of course it is not a true dynamic simulator (not generating motion, collision, etc) but you can make your fibers to grow regarding of the world Y-Axis (instead of the Polygon Normal you are using now), that allows you to grow your grass/hair vertically (up or down) no matter the orientation of the polygon, which is more natural on fibers growth.
Attached an example I created quickly in Studio with the parameters you can use as an starting point.
Let me know if this is what you were after.
Greetings
Dario Lanza
By dariolanza
#381542
Ok, we will check for next versions to allow the Grass and Scatter modifiers (any modifier in general) to be renamed in its stack in Studio.
Cheers!
Dario Lanza
