By seghier
#381350
hello
i try to render a model with maxwell scatter ; there is many instances and for this reason the render take long time ; also i can't use fire
it must turn all maxwell scatter off ! ( 6 maxwell scatters for 4 objects or more )
some parts are missing when i export the model from 3dsmax to studio ; copy paste is solution but i need mirrored part
my wishes :)
- add option to disable / enable maxwell scatter ; grass ; subdivision , under render options
- add option to create mirror object
- save the calculation of maxwell scatters / grass / subdivision , from the first render test to avoid other calculations when rerender the scene
