By philip99
#379227
Hello,
my camera lense is set at 70 in rhino in perspective
when opened in Maxwell mxs I see top, front, right, perspective camera
perspective is 70mm lense but others are 2750.1
is there any way to correct so all is 70 mm ?
thanks
Philip
#379228
The reason is that those other views are using parallel projection in Rhino; the only way to get them to use 70mm would be to switch them to use perspective (open Object Properties and click in an empty part of the viewport), and then set the lens to 70mm.
