By astanelle
#378558
Hello again,
sorry for all the questions :D
I'm having trouble, to give my maxwell sea object a material. it uses the base material, no matter what. tried several projection mods (planar, solid, uv....)
any suggestions ?
item_list Image
shader_tree: Image
fire_view: Image
sample_scene: https://www.dropbox.com/s/mt7icn0kzq43b ... terial.lxo
again: running OS latest, modo 701SP4 maxwell LE beta plugin.
EDIT:
just tested the export to maxwell Studio, base material was assigned to the sea object. the test, cube i added before has the right material assigned.
By gwronkowski
#386085
It seems that it's not implemented yet - can't attach material to Maxwell Sea inside Modo.
Dear developers please add it to your ToDo list, so we can animate Maxwell Sea using Modo.
