#378430
Right now you can lock all of the settings of a camera or none at all. It would be quite nice to have a little check box in each attribute section so you could chose which sections are locked and which ones aren't. Alot of the time, I'll have the camera position set in stone but need to change other settings as i'm rendering. The current locking method isn't efficient for that.
There have been many times where I've accidentally moved my camera, unknowingly, while working in the view port. i would never notice until I tried to comp some renders together and realized one of them have moved...I had left my camera unlocked so I could adjust various camera settings :oops:
Obviously, it's not Maxwell's fault that these errors happen, but it is a reality that they can and do happen from time to time. This tiny addition would be a nice error preventing feature.
