By prodviz
#376946
Hi all,
I'm wanting to output some mattes only.
I switch off the 'Render Color' but the beauty render get calculated too.
Cheers,
Steve
By prodviz
#376951
For now, I set all of the geometry to a black diffuse material and switched off all but the direct lighting.
By Mihnea Balta
#376954
I think this is a limitation in the engine - under some circumstances, the beauty pass is calculated even when it's turned off in the options. I'll check with the core guys and get back to you.
