By jamsurf
#38801
Hi people ,
i have a question about changing configuration of render or scene while
the maxwell render is going render the scene you want to change .
i have heard on forum that you can change things and this changes goes
to maxwell and make effective while this is rendering .
is this true ? and how is this posible to make .
i can change the properties of a material or light and this goes , or is
only a posibility of change the controls of maxwell interface ( burn , iso ,..)
Thanks all by your great support ,
i hope to one day can contribute . Soon i will try some tests .
You can change the settings you see in the mxi viewer under the render settings (or is it render options?) tab. You can't change materials while the scene is rendering.
By Micha
#38930
Mihai Iliuta wrote:.... You can't change materials while the scene is rendering.
This option I have seen by AIR from www.sitexgraphics.com with TweakAir. Could be good for Maxwell too in the far future.
