- Thu Oct 31, 2013 7:49 pm
#372748
This seems to be a hard question for me formulate but maybe someone can see what we're getting at here....
Is it possible to have a film back size with a height larger than 24mm be completely (full frame, edge to edge) visible in the Rhino viewport when the output resolution is set manually?....or even if its on the viewport preset?
We've never been able to input our actual camera sensor size (36.7 x 49mm) into the film back field, match our camera lens focal length, and be able to see the edges of our renderable area in the Rhino viewport. We've developed a pretty robust workaround maintaining the film ratio and recalculating our lens focal lengths to match (or be close enough) but its always kind of bugged me that I don't know what's going on here.
Seems that the viewport is relationship is somehow fixed to the height? and if one increases that number the edges of the full render are outside of the visible space and the user is alerted to this via the red hi-lit space to the sides of the visible space.
Can anyone explain...?
- By Mark Bell
- By Mike Amos 20251018183343
