By Ernesto
#371999
If you have a job that was supposed to render in progresive mode, and the system crashes at frame 19.
You will have 19 frames already rendered at the first level of the progresive plan.
So if you try to relaunch the network rendering, it will add only the the same numbers from 1 to 18 but wont add the rest to the list.
i had to create a second job adding frame 19 to 300 separately.
E
