- Mon Sep 02, 2013 11:30 am
#370592
I´m tweaking textures and I´m not quite sure how the linking to MXM files in AC material settings work.
So far, my workflow has been to create and change materials in MR material editor an link the MXM file in AC. Now, as I´m making changes to the material, I´m a bit confused how to make sure that the changes update in the AC model. I´ve tried both checking and unchecking Embed in the scene, as I assumed it should be unchecked, but I haven´t really noticed any difference. Also, the changes I make are mostly in the textures, so I wonder if they are reloaded every time I run Fire to check the textures, or if there is another way.
When making the final render I export to MR Studio, but I prefer being able to set as many of the material settings in AC before export, in order to not having to redo them as the project changes.
I am also assuming that the texture image I load in AC texture settings in order to place and size the texture material is separate from the MXM material, and that I have to reload this separately every time, correct?
