By Ernesto
#369131
Hello,
In the Maxwell Render Interface, there is an option to render, or render via network
I have tried the second but couldn´t make it work up to now.
I started Maxwell node, Maxwell manager and a Maxwell Monitor, then opened the mxs file from the Maxwell render interface, and picked the Render Via Network button, but nothing happened.
Am I missing anything?
Thanks in Advance
Ernesto
By Ernesto
#369134
numerobis wrote:The network render setup dialog should pop up in the manager.
Oh! I see now...
Thanks numerobis
By Ernesto
#369135
Here is what I have found:
I was having the manager, the monitor and the maxwell render interface in the same machine, and in such a case the network render setup dialog open up, but stays hidden behind the Maxwell Interface, and I was not aware that there was something needing my attention in the network render setup dialog.
If I do it from a different machine, it works better, the network render setup dialog opens up in front of the Maxwell Interface!
I found it better.
This might be something to be fixed...
Ernesto
It looks more like a smooth normal problem. Like i[…]
I had some very strong highlights in some material[…]
Daydreamer
Thanks everyone! I didn't want to use volumetrics […]
opening V5 files in v6
just installed latest version for Rhino V6 when I[…]
