By DGA5900
#368471
Hello, I just installed Maxwell plug-in in a new machine. I can see that maxwell works but there is one specific SKP file i open to try to render and it exports, writes, etc. but then when that's done at the bottom left corner of the Maxwell fire window it shows a 'Scene has errors' message with a yellow triangle and an exclamation sign next to it. Anyone had this issue before? could my SKP file be corrupt? I am able to render on another machine with no problem. The new mach. is an XPS 8500, Win 7 pro, Intel Core i7-3770 @ 3.4GHz, 1TB HDD, 12GB DDR3 RAM. I am using the free version of sketchup 8. Any help would be extremely appreciated.
NEVERMIND! I found the problem. I was missing a background HDRI file.
#368477
Just so you know, you can click that little yellow triangle -- this will bring up a page showing error messages that the plugin has received from the render engine.
Maxwell Render V5 Series
Hi Matteo, Yes I am hoping that we will see a fe[…]
MXM data base.
I think that at this point in time Maxwell can't […]
Thanks Fernando If this will work in the next rele[…]
ilgioma - Gallery
Thanks choo-chee I am very pleased that you like i[…]
